Results 1 to 7 of 7
Thread: welded in 34 chief case baffles
    Oct 2002
    129 greenwood circle milford pa 18337
    252
    Default welded in 34 chief case baffles
    someone welded in these strips of aluminum to replace broken out baffles, what do you think? leave or remove? also does anyone recognize this ride control thanks chris
    4,298
    Chris!
    It looks like a Crocker Chief dampener with a 'custom' knob.
    The case repair depends entirely upon the skills of the welder, and the machinist who then fitted the mains.
    If the cases did not distort, it was worth it.
    PS: Example shown was found in a barn floor with a garden 'claw'.
    It illustrates that the brass stem was fragile, broken off in the nut, probably explaining your odd knob.
    Frame bracket on right was by Michael Breeding.
    Quote Originally Posted by cscott View Post
    If you're using oil control rings on your pistons, you probably don't need baffles. If you don't know the history/quality of the work, I'd say taking them out would be the safe bet. That's my thought.
    Kevin
    1941 Indian Chief - Sonny
    1969 BMW R60US
    1973 Moto Guzzi Eldorado
    Etcetera
    In an H-D engine, the baffle slot is only a bit larger than the widest path of the rod beam (plus extra side-play for wear). The purpose is to create vacuum under the rising piston to draw oil (collected by splash under the baffle) up into the cylinder. Bore area slot area = large number. Since the rear cylinder gets some from flywheel throw-off, later engines only have a front baffle.
    The Indian baffle slot is much wider. Bore area slot area = smaller number. Why?
    Jun 2007
    Catonsville,Md.
    175
    Iwould leave them in if clearance ok,but take to competent welder to check out. The rocker shafts Need inspection closely.
    Menomonie, WI
    1,263
    I'd leave them in.
    4,298
    I dunno Kitabel!
    But here's my never-to-be-finished 334;
    The front rod slot is ~5/8" wide, the rear a fat 15/16", both for a ~3/8" wide rod.
    Note the holes in the front baffle.
    Some say it is to aspirate upward, however it is obvious that they would also be drains when the motor stopped.
    I chose not to repair, nor remove the broken baffles.
    Removal allows the cases to flex, and weld repairs usually distort enough to require re-decking.
    I'd inspect the cylinder decks first, Chris!
