Results 11 to 20 of 26
Thread: Hard shifting into 3rd gear
    West Coast Florida
    180
    What role could a mis-alligned shifter fork play in this problem?
    If you have an allignment tool I would check the shifter fork spacing prior to disassembly just to be sure they are spaced correctly.
    Apr 2010
    1,103
    I always grind a lead in on Andrews shift forks
    Ohio
    656
    Forks or do you mean clutches? Thanks.
    Bob Rice #6738
    Apr 2010
    1,103
    Forks..the edges catch on the clutches.There is a gear clearance problem with one of them that needs to be closely looked at also.Spin thru everything checking for smooth operation
    Ohio
    656
    I was talking to a friend of mind today and he mentioned of taking a tranny apart that was hard to shift and he found that the lock tab for the shifting fork bushing had never been bent over and nut had worked itself loose ruining the proper positioning of the fork. Just another thought.
    Bob Rice #6738
    Nov 2018
    Lowell,ma
    23
    It could be as simple as readjusting the shifting forks with a shifting fork gage. “Took a long ride today” ? That’s kinda cruel to some of us ! Happy new year. Wow ! I feel stupid , yesterdays posts did not appear till I posted this, which is mostly repeating them. Also,where the heck did. Those weird capital As come from?
    4,124
    I want to thank all that responded with usable insight, and knowledge. I'll copy these replies and refer to them when I pull the transmission for repair. Jcadams, we do have nice weather here in Florida in the winter; but we also have millions of tourists in season, and apparently they don't have traffic laws where they come from
    Dec 2014
    121
    Ditto this. If it comes apart, might be worth checking into. I'll even cast a sharp eye to an OEM one.
    May 2009
    131
    What does the lead look like?
    Apr 2010
    1,103
    Taper the fork in the direction the shift clutch turns into the shift fork.[lead in]A little more than taking a burr off.
