Results 1 to 5 of 5
Thread: exhaust cover lengths
  1. #1
    Default exhaust cover lengths
    Anyone out there have a stock set of "slinkys" who could measure their lengths in the extended position? I think I have 2 fronts, and I want to cut one back to fit the rear exhaust pipe on my rigid frame panhead. Any help would be appreciated.
  2. #2
    Sep 2005
    Sarasota, Florida
    3,991
    I notice you haven't had any replies, so I've got to figure no one has a stock set. Personally, I would just cut the rear to fit the pipe, as I believe there can be extenuating factors that would make for variable applications. I think the best solution would be to study period photos, and count the number of coils, or note the appearance of the coils at various bends in the pipe.
    Jul 2002
    5,363
    The length of the front differs between Panheads and Knuckleheads because of the different placement of the pipe to frame clamp.
  4. #4
    Thanks Chris and Eric for your replies. Your idea to count the coils is a good one Eric. And yes, Chris, the front would be shorter for I believe pre-'47 because of the front pipe clamp placement.
  5. #5
    Aug 2004
    Beautiful Northern New Mexico
    2,607
    Short fronts also are used with a sidecar. Rears differ from Pan to Knuckle due to the pipe bell, etc.
