Results 11 to 13 of 13
Thread: 48 Chief Build in Eastern WA
    Jun 2007
    Catonsville,Md.
    161
    Quote Originally Posted by gkpjxb View Post
    Would appreciate a bit of wire wire routing guidance.
    Have all the sheet metal prepped for paint. Want to have all the new wiring in place especially at the ignition switch before painting the fuel tanks. Don't want to attach and remove the painted tanks multiple times to get the wiring correct in that small cavity between the tanks. Was hoping for a few helpful pics and guidance concerning the 4 wires exiting the bottom of the handle bars. Should all 4 of these wires be slipped thru a short piece of that 5/16" black wire cover, to a point at just to the top of the frame headstock? Also, the 2 wires that attach to the horn terminals, also exiting the handlebars, along with the fender lamp wire. Should these 3 wires be fitted through another piece of wire cover as they're routed thru the girder fork shock spring area?
    Thanks for any assistance.
    As far as I've looked the sleeve comes from the bars down to the instrument cover and then uses another cover to the front end from there. Horn wire goes towards ign. switch and then down frame to horn and no cover.
    Mar 2013
    Eastern Washington
    19
    Thanks for the link. Yes is is helpful.
    Mar 2013
    Eastern Washington
    19
    Ok. Thanks for the guidance.
