Results 1 to 6 of 6
Thread: Electric starter for my 80 incher
    Default Electric starter for my 80 incher
    Does anyone out there have an electric starter on their Chief? I'm wondering if they stand up to a high compression 80" motor with Bonneville Cams. I'm getting to old to keep kicking this beast over.
    Jan 2016
    135
    Get a hold of Kiwi Indian in California, he has very good starters for these bikes!
    Aug 2006
    So Cal
    898
    Just a personal view, I spent some time at Kiwi's shop a while back and he demonstrated his starters. I was real impressed with them. I don't want one myself, but thought they looked and worked very well - good luck.
    Apr 2008
    Oak View, CA.
    65
    I have two different electric starter set-ups for sale. One is a Tom Fusco Starter WITHOUT the kicker assy for a plunger frame, with a separate battery box, and mounting instructions. The other starter is from Timmerman (now deceased)in Germany. This one has a kicker pedal assy, but didn't come with any instructions (I copied the Fusco instructions, and used them). It needs a different sprag bearing, and it was initially purchased for use in my rigid frame. Both are actually Sportster starters, with nice machine work and quality throughout. Both starters set-ups have been fitted and mounted, but NEVER actually tested or used. I have had these for quite awhile, because I have an artificial knee. I have trained myself to start my bikes with my left leg, so I am willing to sell these starter units at a reduced price. Alot less than the KIWI units. I will entertain reasonable offers above $500 for either set-up. PM me for details. ChiefTwoKicks@hotmail.com These starter kits are heavy, so postage will be substantial.
    Mar 2016
    Portland, OR
    29
    I put a Fusco one on my '47 chief sidecar outfit. 84 inch engine with Conley cams. It really needs a very heavy duty battery to turn it over and if it backfires then there goes the sprang bearing. They are very expensive to replace. Finally found one in Boise Idaho. A friend talked about putting a compression release valve in the heads. I have an extra set of heads and will probably have him do that. Kiwi's set up looks a lot easier to install and much cleaner appearance on the bike, however, I understand that he will only sell if he installs the setup. Check with him about this if you decide to put the electric start on your bike.
    Thanks Guys,
    I haven't decided what I'm going to do yet. I would still like to hear from anyone using one to see how they hold up. I do like the idea of compression releases though.
