Results 1 to 10 of 12
Thread: acceptable paint color for cylinders/heads
    Default acceptable paint color for cylinders/heads
    What color "silver" or "aluminum is acceptable for cylinders/heads on a 1965 panhead. I have seen both lasted and painted. Thanks
    2,738
    Cylinders were high temp aluminum color, heads are raw as cast, not painted.
    Dec 2001
    425
    High heat cylinder paint H-D 98669-78 part number
    DrSprocket
    Jul 2001
    607
    Yep - what Rubone and RichO said. The original high heat HD paint looks the best frankly. One of those little cans is more than enough to do a couple bikes. I kept several cans when I was searching to make sure I would be able to do touch ups, etc.
    Ray
    AMCA #7140
    Mar 2014
    29
    As others said. Make sure to spend the money on the Harley Davidson spray can. Part # on my cans are 98606EL High Temp Silver/Grey. Metallic Acrylic. Did my '65 cylinders about 8 years ago and still look good. Ridden daily.
    Apr 2010
    1,110
    Mine is Harley #98860-78 Heat resistant silver
    Sep 2010
    Arroyo Grande CA
    25
    I have this one in the cHPIM1863.jpgan with what looks to be an earlier part number.
    Jul 2001
    607
    Thats the AMF one and should work fine. It's really just "radiator" paint. But what's special about it is that the Harley Silver high heat is such a specialty color that no one would want to make it and sell it. Originally it's probably because they actually used real silver in the original formulation way back. When you move from that the color will change. One of those small cans is enough to do a bunch of bikes. "Just use regular high heat silver paint and get over it" Which I would agree with unless you are doing a period specific restoration. Other than that just move on and get high heat silver paint and use it in the right spots.
    Ray
    AMCA #7140
    Apr 2010
    1,110
    If you use VHT it will discolor quickly
    4,214
    Look like nickel, Duffey?
