Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 1965 Panhead Tanks
    Mar 2009
    135
    Default 1965 Panhead Tanks
    I have asked on this question on another forum (caimag), but am also making the inquiry here as well.
    Is there a template out there for getting the correct location of the color scheme for the 1965 Panhead tanks?
    Going to be starting on my 65 this Fall and trying to get my ducks lined up ahead of time so I do not end up at a stand still with the paint. I would like to use the same painter that did my 49 sheetmetal but to my knowledge he has never done a paint set for 1965 models.
    Any help or leads appreciated.
    4,339
    Great question, Panz4ever!
    I have two sets in black waiting a few years for the Birch White.
    Problem is mine are 3.5s;
    There are dual 'consensus' for the layout, and I only want to do it twice.
    (Even precise photos would be appreciated, thanks in advance,...)
    Dec 2009
    Upstate NY
    120
    Hey panz4ever.... I have 3 pics of an OP right tank with a seamstress's tape up against it. It's what i used to paint my wife's '65. Attachment 22591Attachment 22591Attachment 22592Attachment 22593
    Dec 2001
    321
    The photos you show are of my bike. If you tell me EXACTLY what measurements or photos you need I will try to help if you like.
    Mar 2009
    135
    Quote Originally Posted by Omarttentmaker View Post
    K...good start. Thanks
    Quote Originally Posted by jwl View Post
    jwl, my tanks are 5 gal and it looks like yours in the pics are as well.
    Guess precise pics with the tape will help. Want to be able to duplicate the exact position of the striping (as well as width) and depth of the blue before the lower Birch white panel kicks in.
    Need to be able to see/determine exactly where you positioned your tape (pic block that) in order to correctly loctae the solid top, stripe, and solid bottom.
    Dec 2001
    321
    Quote Originally Posted by panz4ever View Post
    My tanks, the ones in Cotten's pics, are 3.5. As you can see, the emblem is in the lower color. On 5's, the emblem is in the upper color.
    Dec 2009
    Upstate NY
    120
    The tape starts at the intersection of the bung and the top of the tank.
    4,339
    JWL!
    Since its all going to be "eyeballed" anyway, I would appreciate just a few level shots from the sides, top, and front.
    (The little thumbnails are futile...)
    And the width of the stripe of course.
    (If its easiest send them to liberty@npoint.net)
    Many thanks!
    PS: I found out the hard way Folks,
    Never lay out tank panels or badges without hanging both tanks on a frame and stand back for perspective.
    Dec 2001
    321
    JWL!
    Many thanks!
    Tom, I emailed you 6 pictures in 2 separate emails. Please let me know if you don't get them and I will try again. John Lindemann
    4,339
    Got 'em, John!
    And I'll share them with whomever wishes...
    I appreciate that you measured out everything and all, but such close pics are like looking through a telescope.
    At your convenience (my two paint jobs are already a decade and a half in progress...) it would be great to get a perspective a bit farther away.
    How did the Factory lay them out, anyway?
    PS: I'm off to Davenport, so it may be a while before I can digest them.
