I've owned this bike for a year and put 2,100 trouble free miles on it. A couple weeks ago while riding on a country road it started missing, sputtering, blubbering when giving it throttle. First I thought it was a plug wire off or something causing a bad miss. When I got pulled over found nothing wrong with plug wires. It would start and idle, but stumble and cough and spit as soon as you gave it throttle. I finally discovered gas dripping out of the air cleaner cover. Took the air cleaner off and found no external leaks, no float bowl overflow. But looking down the throat could see gas spurting out of the main jet discharge tube as soon as I twisted the throttle. Obviously way too rich to run right and excess would drip out the backplate. With no real experience on carburetors I studied the S & S book, did some on line research, and talked to S & S technical support. They thought doing a rebuild kit should solve whatever the problem was. So I took it apart, did a Berryman Chem Dip cleaning routine, and installed every new part from an S & S Master Rebuild kit. Coming apart there did not appear to be anything out of line, and everything went back together very smoothly. Also put in new spark plugs in case the old were fouled. Back on the bike, it's doing the exact same thing. It has a .070 main jet and .0295 intermediate jet, which are appropriate for the 74" motor. I called S & S technical again and they were baffled. And so am I...any insights as to what to do would be greatly appreciated.
