Results 1 to 10 of 18
Thread: 1931 4 running VERY HOT
    Default 1931 4 running VERY HOT
    Last year I purchased a restored 1931 4. It currently has about 450 miles on the rebuild. It ran quite well last summer, but I could tell there was some fine tuning needed and a thing here or there that needed some attention. This summer however the adjustments I've made to the carb to get it running better went so lien and hot that it blistered the aluminum manifold. Let me tell you how I have the bike set up currently and see if someone can help from there.
    First off, I'm in Salt Lake City at about 4,800 ft elevation, so my air is a bit thin. I have the intake valves set at .004. The exhaust valves at .008. I've refaced the exhaust header surface to get it milled flat and have installed new exhaust gaskets with gasket seal to try and close off any exhaust leaks. I have a new gasket between the carb and the intake manifold. As far as I can tell the engine is sealed up pretty well. At least as well as a 31 can be I guess.
    I recently talked with Tom Cotton to learn more about my carb (schebler dlx). He indicated I should start the carb adjustments at 3 turns out on the low idle and 1-1/2 on the high idle. At that setting the bike starts easily and achieving a decent idle at full advance is not an issue,(I would however like to know about what the RPM's should be at idle at full advance).
    At that setting however the bike is just under powered and backs up with fuel. If I lean out the low idle screw (screw on the exterior side of the carb) a 1/4 to 1/2 a turn the bike smooths out and starts to pull like I'd expect, but then it just starts running super hot. So much so it blisters the manifold, again! I shot the cylinder heads with a heat gun after a quick test 10 minute test run and I have head temps of 350 to 390 degrees, so hot it's turning my head gaskets into charcoal, literally turns them to black dust. What's frustrating is I didn't have this problem last summer.
    I'm adjusting the low idle after the bike is warmed up with the bike fully advanced and at 3 turns out I'm getting a black sooty exhaust. From there however I'm at a loss of what to do next. It seems I'm going from to Rich to to Lean and hot withing a click or two of the low idle adjustment.
    So......What am I missing? Do I have the low and high idle screws reversed and am making the wrong adjustments? Could it be something internal of the carb such as the float? I'm out of ideas and would really like to avoid frying the engine. If anyone out there can give me some input or better, yet a step by step guide on how to get this figured out, I'd sure appreciate it.
    Thanks for your help!
    Mar 2010
    154
    Somehow I imagine this will be a subject of much discussion and disagreement, but here's how I adjust the DLX on my 36 Indian Chief and all the Linkerts on my other bikes, including a 1939 Indian 4 (wrong carb).
    I start with the low speed needle backed out from seat position 3.5 to 4 turns and the high speed needle backed out 1.5 turns. This should start the bike in a "rich" position. After the bike is completely unchecked, warmed up and at idle I turn the low speed needle in one notch at a time (slowly) until the bike misfires. At this point I turned the low speed needle back out 1/2 a turn. For high speed adjustment I take the bike on a ride to a location where I can quickly accelerate and back off a number of times. As long as the bike accelerates without hesitation I back off the throttle and turn the high speed needle in one notch. Accelerate again. If the bike accelerates without issue back off and turn the needle in another notch. Repeat until the bike hesitates on acceleration then back the high speed needle out 1/2 turn.
    This procedure works well for me but even among my local buddies, everyone has their own technique.
    Good Luck!
    Steve Slaminko
    4,344
    That's pretty universal, Steve!
    (Except I squint and hold my tongue in my lip just right.)
    But that's assuming all things are in order, and checking for vacuum leaks is a lot easier on twins.
    Carbs are forgiving. Inlet appliances are not, and I can't imagine how you test any Four absolutely.
    Suggestions, Four Folks?
    Steve, any thoughts on the gap I'm running on the intake and exhaust? As mentioned I'm currently at .004 on the intake and .008 on the exhaust. I've been told to set the intake at .002 and most literature I've seen also calls for this setting, but at 4,800 foot elevation seems it might be better to run at .004 or so. Any thoughts?
    Mar 2010
    154
    On the 39 I'm using the specifications call out in the Indian Four Overhaul Manual 2nd Edition. Cold Engine - Intake clearance .002, Exhaust .006. This manual only covers the 438 - 442 Models. Sorry but I have no experience with earlier fours or with higher elevations. While I'm far from understanding the EXACT science of valve timing, I don't think a couple thou extra clearance on the exhaust would make much difference. In any case If it was me I'd probably set the exhaust clearance to .006 and adjust the carb as I outlined.
    Cotton's correct on the problem with vacuum leaks but I've got no suggestions on how to check for them on a four.
    thanks, every bit of input helps a ton.
    Jan 2008
    178
    On my 440, warmed up and at idle I turn the low speed in one click at a time until the engine starts to miss. I then turn the low speed out one click at a time (and count the number of clicks) until the engine starts to load up. I then turn the low speed back in 1/2 the number of clicks I turned it out. Set the high speed as previously outlined and then recheck the low speed.
    Jan 2008
    178
    I know of an owner of a 1929 Indian four with sidecar who was given the bike as a birthday present by his wife. He had never owned a motorcycle before. Apparently the oil dipstick blade had fallen off the cap. He assumed it was like a car and the oil level would never go down so never checked the oil because there was no dipstick. The engine got so hot the aluminum exhaust manifold actually melted off. These engines require that the oil level be kept to the full mark Also a light enough oil to get lots of flow through the bearings instead the pump bypass. Cooling for the top end depends on lots of oil being flung from the rod bearings to the cylinder walls and piston undersides. The original early Indian 4 riders manual calls for #30 oil for temperatures up to 65 degrees.
    thanks for your thoughts. It's about 95+ degrees around here right now so I'm running 50 weight. I would think that would keep me in the safe zone, but I'll double check and make sure the oil level is topped off.
    One additional question or comment from your previous post, when your making your adjustments where is your advance set while making the adjustment? Are your making the adjustments fully retarded, half and half, or fully advanced?
    Thus far I've been fully advanced when adjusting the low idle screw. Maybe that's not the position I should be using????
