Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Gas Tank Restoration
  1. #21
    Nov 2018
    Lowell,ma
    24
    Sorry for your bad luck with por 15 but I would use again in a minute. Maybe it’s not meant for glass
  2. #22
    Hello, this is a topic in a slightly different direction but this thread seems appropriate to ask my question, which is; how does one go about removing an old poorly done tanks seal job and I believe by the looks of it, it is what is branded as "Cream" sealant? Thanks. TL
  3. #23
    4,339
    Quote Originally Posted by Jcadams View Post
    Sorry for your bad luck with por 15 but I would use again in a minute. Maybe itís not meant for glass
    That's was the manufacturer's response, JCA!
    Still, the glass test proves it is certainly not inert in P4gas.
    Don't dip floats in it, either.
  4. #24
    4,176
    Quote Originally Posted by TomL View Post
    TL, I have used paint remover (paste type) with very good success. MEK will also work, but it costs a lot more, evaporates quickly, and will leak out when it eats it's way through a pinhole. Paste type paint remover will cling to the sides, and top of tank and do it's job. When it's done, use MEK to remove residue. Paint remover, MEK, acetone, etc. are all messy, toxic, potentially dangerous affairs, so be careful, and use in a well ventilated place, with gloves, and eye protection. I also re-use old paint remover as it doesn't really go bad.
    Nov 2018
    Lowell,ma
    24
    I used to hear of it failing all the time in the early 80s,then it seemed to go away. Unfortionately I never heard of a remedy.
  6. #26
    4,339
    Ironidally, Folks,..
    Early '80s Kreme worked fine! I still have some in veteran tanks (albeit dry through modern fuel changes of the last decade).
    It even adhered to materials other than bare steel, with proper prep of course..
    Then apparently the sealer's formula changed as well, probably because of regulated toxics, and removal became the issue.
    Such ever changing variables make any sealer a risk.
    The agony of removal far exceeds the benefits, except perhaps for terneplate tanks.
    A soak isn't going to completely remove it.
    You will need a mechanical action as well, such as tumbling with abrasives.
  7. #27
    Of course you have a rig to spin tanks!!!!!
    Everyone talks about wrapping them in blankets and putting them in a clothes dryer, your way obviously is much better, and again, of course YOU made one. Good for Cotten!
  8. #28
    4,339
    Well, Architect,...
    First, I burnt up a Red Devil paint shaker trying to slow it with the wrong control, or somethin'.
    Otherwise, the media stayed suspended off the walls in a cloud.
    Then I tried to make a vibratory table out of an old scroll saw that was powered by a big growler-style coil.
    Took too long.
    But so does my paddle wheel design at 1 rps.
    PS: The dryer is worth a try if it is disposable. A pair of bobs quarter-full of aquarium gravel might be tricky to balance.
  9. #29
    Apr 2013
    200
    Not to hijack this thread but has anyone ever used the fuel tank sealing products made by "Hirsch" ??
    Dan
