Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Knucklehead repair
  1. #21
    Jun 2001
    Central Illinois, USA
    3,493
    For Folks who still insist upon a 'splice',..
    Here's your raw fin stock: 5" X 3" X ~.100" sawn cast iron plates.
    Email me at liberty@npoint.net with your address, and you can have one for the postage.
    and Good Luck!
  2. #22
    Apr 2008
    Upper Yarra Valley, Victoria. Australia
    850
    Thanks Cotton. I'm sure you will get requests for that material as they would help someone fix a head.
    I used up the small pack of electrodes that I had, so ordered a new pack and got this head a bit further along.
    Bolted it to the mill and machined off the high's of the pre-welded areas so that the rocker box could be installed, and used as an assembly jig.
    For a bit of fun, I fit a 3/8” end mill and cut the sides of the middle mount. I’ll burr grind the end to assimilate the original shape at a later stage.
    Used a cardboard template to get the shape of the missing part of the rocker box support.
    Then cut and ground Carl's replacement part to shape. When that was done I bolted the rocker box shafts to the tower supports and the new piece under the rocker box and tacked each end.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
  3. #23
    Apr 2008
    850
    I pre heated the head before tacking the mount in place but a couple of stress fractures still opened up after the tacks and bottom welds were laid. One crack is seen in the previous picture, on the outside fin, beside the tack. The other is between the area to be welded and the vertical fin with the scriber pointing to it. The cracks may be the result of the tacks, or may have been hidden fractures from the original trauma on the head.
    Steve Little
    Australia.
    AMCA member 1950
  4. #24
    Sep 2005
    Sarasota, Florida
    3,675
    I know next to nothing about metallurgy, or welding but can stress relieving minimize stress cracks like that? By stress relieving, I mean shot peening, heat cycling, or vibratory shaking prior to welding; or is stress relieving suppose to be done after welding? Just wondering for the sake of conversation. I really appreciate you sharing your process, Steve.
    Jun 2001
    3,493
    That's why I am not a pro welder, Steve!
    It would seem that your filler material shrank more than the casting would allow.
  6. #26
    Apr 2008
    850
    Hi Eric and Cotton. Thanks for livening up the thread and contributing ideas and comments.
    Aside from pre and post heating the head, I have a chipping hammer and a sharpened file that I used for chipping the slag off and tink, tink, tinking the weld after each pass.
    Placing the head in lime for a slower cool down might have been the ticket for success. Learning and sharing the quirkiness of cast iron and gaining some experience along the way, is what it’s about.
    I used the angle grinder to grind down from the top of the joined area until I reached the weld that I had laid underneath the bracket. I also ground a nice V into the crack which was near the vertical fin and then pre-heated the head and welded both areas. Then back in the oven for an hour and then tried a new method…suggested earlier on....lowered the oven by 20 degree increments every hour and then left it in the oven over night. I left it at a temperature that was just bearable to the touch….for an old boilermaker/welders hand that is.
    Clamped the head into the mill and took the welds down to the original metal. Then drilled and tapped the middle bracket.
    Getting closer and closer to usable heads.
    Steve Little
    Australia.
    AMCA member 1950
  7. #27
    Jun 2001
    3,493
    Ever remove a bearing race by welding a bead around it, Steve?
    Kyle Oanes and I discussed this once, and my contention was that the tool steel shrank when it reached a critical temperature, and Kyle contended that the bead shrank and pulled the race smaller.
    We were both half-right.
    I think your filler rod has a high shrink rate, and if you have "slag", its a bother as well.
    Please look at the pic I posted earlier, where the bead has been ground away to show complete penetration, and virtually no visible difference with the casting.
    There was no flux used, so there was no slag. Primitive.
