This tool that is made from an old, discarded spoke has been a real time saver. (Not to mention a lot less cussing) I just cut then off of the spoke head and started grinding until I ended up with the end looking like the end of a straight tip screw driver. (See Pics) Slip it under the lock ring and start pulling back the ring with a scribe. Then work your way around the gear.
Craig
