Thread: 67 Shovelhead Rear Brake
    Jul 2014
    29
    Default 67 Shovelhead Rear Brake
    Can someone tell me what type of washer is used on the outer block that the banjo bolt goes through to the wheel cylinder on the rear drum brake of a 67 Shovelhead? I used copper but it wanted to leak. The manual doesn't indicate.
    Thanks!
    Jul 2008
    North Carolina
    642
    There are (2) copper crush washers (p/n 41744-58) that goes (one each side) on the swivel fitting (p/n 41750-63) that the banjo bolt (p/n 41743-58) passes through.
    William Edwards, AMCA #10035
    Dec 2001
    432
    Available at any good auto parts store. Grooved both sides. Easy to figure i.d and o.d.
    DrSprocket
