Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Pony Riveting Tool
  1. #21
    Oct 2002
    455
    I have a lathe Tom but not proffecent on it yet.
    Since then I completely rebuilt it and added a Bison chuck and Dorian tool post with tooling.
    AMCA #765
  2. #22
    4,291
    It looks like a good size and vintage, Len!
    How do you lower the toolpost?
  3. #23
    Oct 2002
    455
    That's some old pics and wasn't done with the rebuild with an old tool post.
    Newer pics but still have to install the new feed half nut and screw bushingings in the compound. it's a 12".
    AMCA #765
  4. #24
    4,291
    I like that post a lot better, Len!
    'We' (the 'royal' "We".. like the good ol' days when Liberty had a crew ,..) must make do with most anything; My 'budget' Harbor Freight quick-change stays 'dedicated' to some critical operations, while relying upon a couple of lantern posts for most everything else.
    Except when clamping an old sewing machine motor or Dremel to something carved in the eighties...
    The real trick to making rivet rams will be picking the material, or search out a 'practical' hardening recipe.
  5. #25
    Ohio
    673
    Len, I think those rivet tools would be a good project for you to get your feet wet with that lathe this spring. Try and get some sketches and dimensions from your friend that won't allow the tools out of his sight, why? I know I will get disagreements but here I go, I would use S-7 tool steel. It is a shock resistant steel used in exact applications as this. I make parts from it almost weekly. It is not real expensive. When heat treated to somewhere in the 52-54Rc range it will only change slightly, but will be hard enough and forgiving enough for this exact application. If needed I can send some out to you. I will also offer to heat treat them for you, I go weekly to heat treat and a few more pieces in the lot would be consumed in my minimum charge. PM me if you want to go that route. I could also do whatever end form you need if you just wanted to blank them out.
    Bob Rice #6738
  6. #26
    4,291
    Well, Len...
    Bob's got your recipe!
    I see your intuition came through and you stiiffened your table with plate.
    Mine is similar, but it coulda shoulda been more.
    Hope to move my Logan to a slab of pool table slate... .. .. someday.
  7. #27
    4,291
    Back to topic almost,....
    This thing fits in the palm of your hand;
    It has "Dc" with the c underscored, and 'Paris' on the other side,
    Cute as a puppy, and a long story to go with it.
  8. #28
    Mar 2017
    283
    Drivers for the pony riveters are around 15 bucks for rolled or splayed rivets. Rolled for metal, splayed for leather and such. I will give a supplier for rivets, almost any type of buckles and all kinds of tooling for the stand up riveters. They also have all kinds of materials and fastners. Well worth calling for a free catalog. They are Amish, so no web site.
    Beiler's Supply 717-768-0174
    S-7 is a great, air hard, material to work with. I used s-7 for cavity blocks on one half of plastic injection molds and h13 on the other half. H13 tig rod gives you a 50-54 hc tough surface just from welding with it and letting it cool.
  9. #29
    Mar 2017
    283
    Cotten's post 27: That is an eyelet setter for shoe repair. I'm sure you already know that Cotten. Lol
  10. #30
    4,291
    Not exactly, Ryan!
    It would require a pretty small shoestring, and they were still using buttonhooks back then.
    (I suspect Hexter's became my neighbor Loy's 'dime store' in the thirties, but the Loys are no longer with us to ask...)
    This tiny riveter was in an old watch repair dumpster load, about four doors away.
    (Note Linkert float gauge beneath it.)
    I consider all such presses (like my Pacific) to be multi-purpose tooling!
