Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Sidecar brakes
  1. #1
    Jun 2005
    Northern Colorado
    785
    Default Sidecar brakes
    Does anyone have a juice brake set up, or a backing plate for a 58 thru 75 or so side car? I'm trying to make a 50 LE work on a Duo-Glide.
    VPH-D
  2. #2
    Jun 2001
    Central Illinois, USA
    3,608
    Golly VPH-D!
    It will work fine with no brake at all.
  3. #3
    Jun 2005
    Northern Colorado
    785
    You're serious?
    VPH-D
  4. #4
    I don't run the sidecar brake on my '49.they are a fickle thing to setup.If you get too much sidecar brake it takes you for a right hand circle.too little & it is the same as no brake.Late models I have rode that have a seperate pedal or a hand lever to actuate the car brake work pretty good.When you really need it you have a little extra stop power.
  5. #5
    Aug 2004
    Beautiful Northern New Mexico
    2,392
    I always set up the sidecar brakes, if set-up correctly you will stop straight and true. Not hard to do and definitely add to the stopping power. I guess living in the mountains creates a different mind set.
  6. #6
    Jun 2001
    3,608
    Quote Originally Posted by VPH-D View Post
    You're serious?
    VPH-D
    You bet, VPH-D!
    I believe the owner' handbooks speak of "if" you run a brake.
    Rigids can be tuned, but its just easier to put a hydraulic on the shelf.
    Why bother with it if you must defeat its action anyway?
    Mine's in the basement somewhere, packed away thirty-eight years ago.
  7. #7
    Jan 2006
    Menomonie, WI
    1,152
    I also am a firm believer in a operational sidecar brake. Carrying a big load down the mountains on the first Cannonball (2010) re-enforced this idea. Jerry
  8. #8
    I agree with hills & traffic.Pretty flat where i ride & I don't ride during the 20 minute rush hour!
  9. #9
    Jun 2001
    3,608
    Just for clarity, Folks,..
    This discussion was about hooking up to a DuoGlide.
    Running no hack brake pulls you gently to the left.
    A hydraulic hack brake pulls you hard to the right.
    Smaller shoes didn't help much.
    Backing off the shoes just means it grabs later.
    Considering my wife's upper body mass, no brake was most comfortable. She knows the limits of the machine.
    PS: VPH-D's real question was whether a hydraulic brake would bolt up to a mechanical chassis.
    I can't easily get to my '39... Or my hydraulic brake!
  10. #10
    Aug 2004
    2,392
    And he got that answered. You brought up the NO BRAKE thing. This thread just just him looking for parts...
