Results 1 to 10 of 12
Thread: 56 panhead rear fender wiring
    Default 56 panhead rear fender wiring
    does anyone know where the taillight wiring exits the rear fender.
    Feb 2010
    318
    Into the taillight.
    out of the fender towards the battery
    2,543
    What are you dealing with? A repop fender? Factory fenders have an exit hole in them that is pretty self explanatory.
    Taiwan tedd repop
    Nov 2009
    Reynolds,ND/Queen Valley,AZ
    115
    On mine From memory(I am not out in shop at moment) on the moveable end part of fender there is a closed metal channel under the tail light, then a metal coil/spring type conduit spanning the hinge area that goes to an open type U channel with metal tabs bent over to hold wire in. This channel runs in an arch along the side of the fender that exits the fender through a hole near the chain cutout. If no one else chimes in I will go out tomorrow and verify what I just said.
    Nov 2009
    115
    Oops sorry I should have mentioned, mine is a 50 and my other a 49 is the same. But I would think 56 would be the same.
    2,543
    If you look closely you see the wire comes out just below the frame rail, then is routed along the inside of it to the terminal box. The ends of the clip holding the wire are visible . This is a '54 but '56 is the same.
    Got it thanks for the help
    5,317
