Results 11 to 12 of 12
Thread: shovel engine on hd rigid frame
    Menomonie, WI
    1,262
    Actually what HD did in 1948 was to rotate the Panhead engine forward 3 degrees apparently to help with seatpost area clearance. If you put a panhead case up to a knucklehead case there is no height difference but the angle of the milled motor mount deck is slightly different.
    Jerry
    4,293
    That's a revelation to me, Jerry!
    It might explain some of my mistakes...
