Results 1 to 2 of 2
Thread: 1911 Harley Davidson Single Cylinder Wiring
    Jul 2013
    9
    Default 1911 Harley Davidson Single Cylinder Wiring
    Does any one have a wiring diagram for an 11 single battery model? What is the best battery to use? Have a 12volt coil.
    Thank you,
    Ric
    3,557
    This is a typical wiring diagram for an early battery ignition system. In the early days, motorcycles used those big round dry cell batteries that were common up into the 1970s. 12 volt will work fine, but if you're trying to replicate the correct look, you'll most likely have to fabricate something on your own. Hope this helps.
