Results 1 to 2 of 2
Thread: Chain Guaurd 60308-67
    Default Chain Guaurd 60308-67
    I canít find a reliable image of a 60308-67 chain guard. If anyone has a picture please post it. Iím assuming it is the guard with 4 rivets on the front mount and a horizontal rear mount. Is this a correct assumption?
    No it's not correct according to the Parts Book. The version you describe is 60303-52A or 60303-56. The 60308-67, 67-71 XLH also 60308-70 used on 70-71 XLCH. The guard for the 60308-67&70 has two verticle mounts with one 5/16th screw each. Hope that helps.
