Results 1 to 10 of 14
Thread: 6V XLCH Taiight Bulbs
    Mar 2005
    777
    Default 6V XLCH Taiight Bulbs
    I'm assembling my completely OEM taillight after painting and notice that there is no way go get the bulb into the socket with the clear upper lens installed. This is the early housing with the vertically-mounted socked assembly. The clear lens is also original, OEM. Also, there is no way to get the clear lens in with the bulb in place. This taillight originally took the G.E. 1154 bulb (H.D. No. 68165-47), the same bulbs as my knucklehead. I'm thinking that the Chinese bulbs that I bought from V-Twin are slightly longer than the original bulbs. This height isn't critical in the knuckle taillight housing, but interferes in the Sportster housing.
    Has anyone experienced this problem and/or what bulbs are you using to allow installation?
    Bill Pedalino
    AMCA 6755
    Mar 2005
    777
    I just found a 10-Pack of old, original AC 1154 bulbs on EBay. I remember the package from when I worked in gas stations in the 1960's. Hopefully, these should fit.
    Bill Pedalino
    AMCA 6755
    Ohio
    596
    Is the bulb overall height different or are the tangs in a different location?
    Bob Rice #6738
    Mar 2005
    777
    Its the overall height. The contact buttons are correctly indexed to the side pins and the contacts in the socket. In fact, I inserted the bulb without the clear lens in-place to check my wiring and both filaments lit up as expected.
    Bill Pedalino
    AMCA 6755
    5,245
    Shouldn't the bulb be laying down instead of standing up?
    Ohio
    596
    In my machine shop trade I do alot of prototypes, make and check the first one, then adjust for production. I can only assume from the many incorrect Chinese made parts that their interpretation of a prototype is a 10,000 part run.
    Bob Rice #6738
    Jun 2009
    PA
    147
    Post a picture of what your dealing with. It should look like this.
    Feb 2010
    316
    Quote Originally Posted by murph View Post
    The 1154 bulb is considerably larger then the one shown.
    Jun 2009
    PA
    147
    True, but I have found the large bulbs can melt the lens.
    Mar 2005
    777
    Bob, You are correct - they do large prototype runs and then dump them on the market at a discounted price.
    Murph; Thanks so much for the photo. I mounted the socket vertically (like in my knucklehead) and that was the problem. You would think the direction of the press-in area would be a hint, huh?? You also state that you substitute a shorter bulb for the 1154. Which bulb do you use? I certainly don't want to melt the original plastic lens; It took awhile to find and it wasn't cheap!
    As of this morning, now that the taillight assembly is installed and working the bike is nearly complete. The tank and fenders are painted Hi-Fi Blue, although the tank is still at the painter for the white side panels, decals and final clear coat.
    After some aggravation (an earlier thumbnail image that I can't seem to delete) I posted a progress shot of the bike taken this morning.
    MERRY CHRISTMAS TO ALL !!
    Bill Pedalino
    AMCA 6755
