Results 1 to 6 of 6
Thread: 62 rear brake master cylinder
    Sep 2010
    SPRINGFIELD,OH
    109
    Default 62 rear brake master cylinder
    anyone out there rebuilding original rear brake master cylinders ? running a/m one now, but have original to rebuild. thanks
    Nov 2008
    Virginia
    448
    You can buy a rebuild kit and do it yourself. Napa has them. If it needs the bore re-sleeved then check Hemming's for folks that do that work. If all it needs is honing you can also do that yourself.
    Tom (Rollo) Hardy
    AMCA #12766
    Sep 2010
    SPRINGFIELD,OH
    109
    thanks tom. i will get it cleaned up and get with local napa on kit. good winter project.
    Oct 2016
    102
    Do you no the NAPA part number? Thanks
    Often after rebuilds the cups get cut by sharp edges from honing.
    Local dealer[back in the day] refused to rebuild them because of comebacks.
    Nov 2008
    Virginia
    448
    No I don't off the top of my head but J&P also carries them part #2400560 $16.65.
    Tom (Rollo) Hardy
    AMCA #12766
