Results 1 to 8 of 8
Thread: 1965 Electra Glide clutch and brake levers
    Oct 2010
    The First State
    107
    Default 1965 Electra Glide clutch and brake levers
    Hello,
    Can someone provide a picture of the correct levers for the clutch and brake on a 1965 Electra Glide? I know there are no holes in the perches since the mirrors clamped to the bars but do the levers have the ball on the end or are they straight? I've been searching but coming up with conflicting results.
    Thanks!
    Craig (Delaware)
    AMCA Member #1011
    Feb 2010
    317
    They are straight and have the ball on the end...the same lever as the later models, but no hole in the perch. Your confusion probably comes from assholes on eBay claiming the lever they are selling is a 1965 with no hole and is in fact a 1964 and back lever.
    Jun 2005
    Northern Colorado
    796
    65 thru 67 levers don't use the white plastic top hat bushings.
    Oct 2010
    The First State
    107
    Quote Originally Posted by upsrod View Post
    Thanks for the clarification. And you are right about the sellers on eBay!
    Craig (Delaware)
    AMCA Member #1011
    Oct 2010
    The First State
    107
    Thank you!
    Craig (Delaware)
    AMCA Member #1011
    Sep 2007
    Jersey City
    2,013
    This info also applies to 1965 Sportsters as well. Bob L
    Here is a picture of '65 lever and brackets
    Oct 2010
    The First State
    107
    Thanks for the picture.
    Craig (Delaware)
    AMCA Member #1011
