Results 1 to 10 of 12
Thread: PIERCE 4 engine timing ??
    Default PIERCE 4 engine timing ??
    Hello, Can anyone help me to time a 1911 PIERCE 4 . i only have timing marks on cams and crank . not intermediate gear How would i set up correctly and also set the magneto .thankyou mike.
    Oct 2011
    335
    Quote Originally Posted by motorheadmike View Post
    I am not familiar with your machine,but since you have 0 replies ,this is how I would try to time with no marks,assuming you can locate tdc on the cylinder your timing.
    Since most of these motors have the valve overlap centered on tdc locate tdc and install cams so exhaust is just closing as intake opens centered on tdc.Rotate crank slightly less than 360,not sure how much advance you require,then set mag to points just breaking in full advance position.
    Probably stuff you are already aware of and possibly wrong but maybe some useful info will come from a discussion.
    Have fun,
    Aug 2009
    rural eastern South Dakota
    934
    Sequence question: Is 1-3-4-2 most common, or 1-2-4-3 ?? Or is there another crank layout of the 4 throw lobes?
    440
    Private message sent
    AFJ
    Apr 2003
    Seaford, NY
    374
    The method tburke3 describes only works on symmetrical timed cams.
    2,392
    Agreed, doesn't work on most Brit twins and many others.
    Aug 2001
    Upminster,Essex,England
    269
    Hello motorheadmike , Have you managed to get her running yet ?? I've just put together a 1909 but with 1912 engine and am having difficulties strarting (yes I know i need a new pair of legs BUT should be easy as a four??) Any help or pointers will be most appreciated . Best wishes , Ken
    Sequence is 1 3 4 2 . That's the way my valves operate .
    Ken
    Aug 2001
    269
    Starting easily now and running nice , still needs a little fettling etc , see on Youtube https://www.youtube.com/watch?v=bfE6...ature=youtu.be
    Ken
    3,771
    What was the main problem, Ken? My biggest problems on Hendersons have been 'ME'; but also, numerous places for air leaks, weak magnetos, and worn out carburetors. Otherwise, 4s are a piece of pie
    Aug 2001
    269
    Ha Ha , same problem , ME !! The problem I found was the exhaust camshaft did not return properly and left the valves whisper thin open but enough to stop the motor starting , anyway all sorted now and starts easily and runs quite nice . Love fours ! Thanks for your interest , Ken
    Ken
