Results 1 to 5 of 5
Thread: 1961 Pan Head hardware
    Nov 2017
    5
    Default 1961 Pan Head hardware
    Can anyone tell me the preferred method of restoring hardware such as case bolts, axles and nuts, bracket hardware etc.
    Also, can you recommend the best manual for restoring to the most accurate cosmetically.
    Thanks in advance,
    Wes M
    3,608
    Wes!
    From what I can tell from responses on this forum: http://www.antiquemotorcycle.org/bbo...157#post166157..
    It just has to look good.
    So you are the final judge, as it should be.
    As far as a "manual", most of us (concerned with H-Ds) consult Palmer's first.
    Good luck!
    5,191
    Restore or refinish? Parkerizing and Cadmium plating put new finishes on old hardware.
    Nov 2017
    5
    Thank you for the response, I found a local cadmium plating Co at a reasonable price.
    5,191
    Quote Originally Posted by wes m View Post
    You can easily do your Parkerizing ay home. Parkerizing chemical can be purchased on eBay.
    https://www.ebay.com/sch/i.html?adpo...dmd=1&_ipg=200
