Results 11 to 14 of 14
Thread: 3391-29A, Control coil clip, rear
    Sep 2001
    Palmerston North, New Zealand
    907
    You're onto it Steve.
    The one on the left in photo 3 is the correct one for 1929.
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
    527
    Tommo, i sent you an email on the 16th and the 15th.
    Default 1929 Rear Cylinder Coil Bracket
    Here are a couple of pictures of the 1929 Rear Cylinder Control Coil Bracket (3391-29A)
    It is the same in every way to 3391-28A except for the change of the mounting hole to a mounting slot.
    For whatever reason, this part is quite rare while the 1929 front brackets (3391-29) are often found. This is one of two that I have EVER owned.
    Mark
    527
    Thank you Mark for those pictures ! Good stuff !!
