Results 1 to 5 of 5
Thread: 36 T Oil Lines?
    Jul 2008
    Richmond, IL
    195
    Default 36 T Oil Lines?
    Does anyone have any 36 Chief T Oil lines or plans for such?
    Thanks.
    D.J. Knott
    AMCA #10930
    Nov 2008
    Virginia
    407
    Mine have been eliminated as a lot of them were back in the day as they were prone to leaking. Might check Greer to see if they offer them.
    Tom (Rollo) Hardy
    AMCA #12766
    Jul 2008
    Richmond, IL
    195
    No go from Greer. He has clamshell covers without the hole for the T lines. Mine were eliminated also, but I thought I would like to at least have one or a pattern.
    D.J. Knott
    AMCA #10930
    Apr 2010
    Austria
    157
    I am quite certain that Indian used the same T-piece as on the gaslines for the T-oillines:
    https://www.jerrygreersengineering.c...d=052ACHF44-48
    Rgds,
    speingfield1901
    Jul 2008
    Richmond, IL
    195
    Quote Originally Posted by gsottl View Post
    I have not seen any pictures that support the use of the gas line T. It might be a solution, but all of the pictures I've seen, seem to be a tube into a tube at 90 degrees.
    The real question is what do they look like where they enter the clamshell valve covers? you cannot see that on assembled units.
    D.J. Knott
    AMCA #10930
