Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: 53' Fender Badge
    Jun 2011
    Nebraska
    24
    Default 53' Fender Badge
    One of my OHV Deluxe fender Badges has a broken 6-32 stud. See the attached photo. The threaded piece on the right is a set screw.
    Any idea on how to repair this without destroying it in the process?
    Jun 2011
    Nebraska
    24
    The welders I know who TIG are shying away from this one.
    I think I will take a hex bolt, 6-32, grind the head thickness down to about .030" and grind the broken stud off. Then I will epoxy the new stud in place. I can make a jig to hold position and squareness while the epoxy sets up.
    3,466
    Ssantelman!
    I am only familiar with repops...
    Is yours potmetal, or brass?
    If its brass, just dress it flat and clean, cut a thin, flat top on a screw, tin both surfaces, and solder it.
    3,647
    As Tom said, if it's brass, you could have success with solder. Personally, I would forget about attaching a new stud, and just glue it on, or used double sided tape on the broken stud side. There are automotive panel adhesives that are as strong as a weld. You already have 2 holes in your fender, and you're never going to take the badge off so use a modern super adhesive. As nice as those badges are, it would be a pity to heat damage the finish, or have a poorly adhered stud break off while your riding.
    3,466
    As Tom said, if it's brass, you could have success with solder. Personally, I would glue it on, or used double sided tape on the broken stud side. There are automotive panel adhesives that are as strong as a weld. You already have 2 holes in your fender, and you're never going to take the badge off so use a modern super adhesive. As nice as those badges are, it would be a pity to heat damage the finish.
    Eric!
    The heat of soldering shouldn't hurt the other side (if its brass).
    Use an iron, not a torch....
    PS: AMWAY's Oven and Grill coating is one of the best 'snake oils' I've pulled out of the dumpster, as I routinely torch out detente balls on carbs without any effect upon original nickel finishes around them.
    5,139
    Use some JB Weld and don't over tighten it again.
    Jun 2011
    Nebraska
    24
    The badges are plated brass; I scratched the plating next to the broken stud.
    I will open and flatten a bushing and try my hand at soldering a screw to it. Thanks for the insight.
    3,466
    Quote Originally Posted by ssantelman View Post
    ..I will open and flatten a bushing...
    After scrupulous prep, use "Rubyfluid" to tin both the badge back and shaved-flat screw head before jigging them (if necessary), and apply heat to the screw with a large iron.
    Patience!
    3,647
    Glue always sounds like a half-assed fix, but I think I would trust it over a solder joint. I agree with Tom, that a high amp soldering iron is the only way to go for a clean solder repair. I just remember spending an hour combing a busy stretch of highway, looking for a genuine fender tip that let go. Studs were still in the fender though
    3,466
    Glue always sounds like a half-assed fix, but I think I would trust it over a solder joint. ...
    Eric!
    Time for a double-positive:
    Yeah, right.
