Results 21 to 30 of 37
Thread: helicoil fight
  1. #21
    Grinding the drillbit in this manner will prevent grabbing. Not as nice as a reamer but will work.
  2. #22
    Ohio
    553
    Good suggestion Larry, I was taught to do that when drilling brass.
    Bob Rice #6738
  3. #23
    Brass and plastic.
  4. #24
    Jan 2016
    145
    I can't quite tell what you did there Larry.What surface is ground? Is this is?661631.jpg Like the one on the right correct?
  5. #25
    3,350
    Just web-search "drill bit angles", Folks!
    Wikipedia has a handy chart for different materials, if you missed it in your highschool text book.
    PS: I thought everybody had seen toys like these...
  6. #26
    Jan 2016
    145
    I bought a Sawzall quite a few years ago and my wife says " don't you have enough tools..."? Uh, no.
  7. #27
    3,350
    Quote Originally Posted by DCoul View Post
    DCoul!
    Next time, remind her that the most important tools are the ones that make more tools.
    Hopefully, she will see the 'economics'.
  8. #28
    Ohio
    553
    Not to speak for Larry which brought up the good point (no pun), the leading (or cutting) edge is dulled or given a negative rake. To explain negative and positive rake is easiest when thinking of a lathe tool, the cutting point is on center but the chip flow is either downward (positive) or upward (negative). It is the way the insert or cutting tool is positioned. With a drill the lead cutting edge is against the chip flow, I guess that is a way to explain it, so it doesn't dig or draw itself into the work piece. Larry, I didn't mean to answer for you and correct me if I'm wrong or if different from your knowledge.
    Bob Rice #6738
  9. #29
    Jan 2016
    145
  10. #30
    3,350
    I don't want to speak for Larry either,...
    And I couldn't copy his pic for an arrow either, so I have attached my own.
    I hope I am correct that Larry wanted to illustrate a chip-breaker-grind shown on the right in my attachment upon a tortured Caterpillar bit.
    Its ugly, probably hand-carved, but graphically demonstrates the technique.
