Thread: Scout spokes and rim questions
    Jan 2016
    147
    Default Scout spokes and rim questions
    My buddy has a 1937 scout. The forks though I believe are off a vertical twin. The spokes are failing and need to be replaced but, the rim says: Made in England. W.M.2.19 Jones and then I think it says NFF.
    The hub says 1239002 2, then an N with a circle around it.
    I attached a couple phots. Trying to get spokes for it. Any ideas? It was a race bike. The spokes that are in it now, look like someone used a washer around the spoke at the hub.
    I would talk to Buchanan's Spoke and Rim! www.buchananspokes.com, Good luck
    Jan 2016
    147
    Thanks Pan 620. It looks like an old BSA, Norton or Triumph rim mated to the Indian hub. Buchanan came up on my search. I'll send him that direction.
