Results 11 to 17 of 17
Thread: Steering Head Lock
    3,680
    Gosh, JSB55,...
    That should get you a hundred-lot from MSC or McMaster-Carr, I think.
    Hope the shipping and handling makes up the difference!
    PS: Mine came out of a dumpster, honest. (But that was 'back in the day' before the Crash o' 'O8. There has been no 'recovery' at the bottom of the food chain.)
    Mar 2009
    543
    Quote Originally Posted by upsrod View Post
    If you didn't drill a hole in the lock body for the pin to go into, the lock has probably backed out and not moving the pin into the neck hole.
    Exactly, Rod. The locks from Bill's Custom Cycle - and other places, he hasn't cornered the market- must be drilled about 1/16" into the lock body. The huge drawback of this method is that the new hole is now 1/64" larger than the original hole as used by the stock solid retaining pin.
    And the lock does rotate freely 360 degrees.
    The spring behind the plunger is not strong enough to push the plunger into the fork stem under any circumstances; especially if ample grease was used upon installation.
    Which reminds me that it doesn't hurt to occasionally grease the plunger on any machine in which the original lock still exists. How? Just hold the grease gun tip against the weep hole under the plunger bore, and pump away. Most of the grease will make a big blobby mess, but *some* will be forced up in and around the plunger, eventually becoming visible in the key slot. I can't tell you how many stuck plungers I've seen, but I can tell you why most fork locks fail.....
    Why *grease*? Because grease fills the voids, discouraging the formation of corrosion.
    (I know I left this conversation open for the many different ways to lubricate the lock and plunger, but as long as it's on our personal Periodic Maintenance Chart, it will have served its purpose. Just don't use WD-40; ask any locksmith.)
    Mar 2009
    543
    Quote Originally Posted by JSB55 View Post
    .....I managed to pull the lock, complete with a nice scratch down the side showing me where I need a little indentation for either the roll pin or a set screw to engage.
    Regardless of where the 'scratch' is, the correct orientation for the key slot is 90* - exactly perpendicular - to the plunger pin.
    3,680
    Grease is a 'good thing', Rooster!
    But if the spring isn't strong enough to do anything, then why use it at all?
    The detente on the back of the core does everything.
    Mar 2009
    543
    ...But if the spring isn't strong enough to do anything, then why use it at all?....Cotten
    To prevent the plunger from getting 'stuck' at the back end of the bore.
    3,680
    Quote Originally Posted by Rooster View Post
    Gimme a break, Rooster!
    The detente on the core might break first?
    (You already said the spring was weak...)
    What keeps it from getting stuck forward?
    (Its obviously more likely to get pinched by the forkstem than the bore in the headstock. The "engineers" just couldn't figure out how to add a spring there!)
    Mar 2009
    543
    I post on this forum to help others when I think I am able to, based on my experience and knowledge. NO, I do not post a lot.
    I do NOT post on this forum to argue with keyboard jockeys who apparently have nothing better to do than argue with other members- over the most asinine and trivial details which mean nothing to people who actually work on and ride their motorcycles.
    Goodbye, Cotton.
