Results 1 to 2 of 2
Thread: 'C' Generator and earlier oil pump on a '28 JD?
    May 2017
    13
    Default 'C' Generator and earlier oil pump on a '28 JD?
    The generator that came with my '28 JD basket case is a 'C' generator. From what I've seen, the 'D' generator would be correct. Any fitment or other issues using the C?
    Also, along the same lines, has non-adjustable type oil pump, but has bracketry attached for adjustable bits. Anything to consider using earlier type oil pump until I come across correct unit?
    Thanks in advance, still have a lot to learn.
    Edit: I don't think adjustable is the right word for the oil pump, perhaps variable is a better descriptor.
    Dave
    I have a sent you a private message about this.
    Peter
