Results 1 to 10 of 20
Thread: 1941 FL Fuel Shut-off
    Aug 2017
    Fort Mill, SC
    9
    Default 1941 FL Fuel Shut-off
    I'm new to this forum and tried to perform a search for this topic. I apologize if it has been covered a million times before.
    My 41 FL is not shutting off the fuel. I don't think it is an alignment problem. My bike is very original and I would like to keep it that way as much as possible. That being said, is there a fuel shutoff assembly I can use to replace the leaking stock assembly that allows me to use my original shut-off operating knobs?
    My original shut-off operating knob is solid and does not have the small operating knob screw through the top. Most kits I see have the wrong type of knob.
    Any advice would be greatly appreciated.
    Thanks,
    Sam
    Jun 2010
    217
    The original knob was attached to the rod with a small screw, if yours differs it is not original.
    You could watch ebay for an original, this is risky as the rod or seat may leak.
    vtwin sells a replica 38-0232
    Aug 2017
    Fort Mill, SC
    9
    thanks for the info. It is very possible that the knob I'm using was replace a long time ago. here is a photo of the knob:
    It has a lot of wear so I assumed.... You know what they say.... I am very interested in an original knob with upgrades working parts.....
    Feb 2010
    314
    The knob shown is a Genuine H-D accessory part #91690-49...so not correct for your '41. The original knob is right below it!
    Aug 2017
    Fort Mill, SC
    9
    Awesome. Thanks for helping me clarify. I am assuming that it replaces the screw? As far as a replacement shaft is concerned, is the V-twin component any good?
    Mar 2009
    543
    There are replacement rods fitted with PEEK tips that invisibly solve the problem.
    V-Twin is not the solution.
    Nov 2008
    Virginia
    443
    Carl Olsen (Carl's Cycle Supply) for sure sells the peek tipped rod assembly and I have installed 4 on my bikes and they work great. You don't need to crank down too hard as the peek material seals well. Also you might want to make sure your needle and seat and float are functioning properly. Especially check the amount of play between the fingers on the float lever and the needle top. Check and set that before you set the float height or your never going to get it right. I used to go in the garage and smelled of gas all the time. Not so now!
    Carl sells the kit for around $100 but everything is brand new and includes the fuel valve, brass washers, peek tipped rod and shut off cap. All you need to do is remove your old stuff and replace it with the new and instead of the screw to hold the cap install your knob. You'll be glad to did!
    Tom (Rollo) Hardy
    AMCA #12766
    3,645
    Quote Originally Posted by eubanks View Post
    Eubanks!
    Five minutes re-cutting the original shut-off shaft on a lathe with the toolpost set at 45 (giving a 90 point) is by far the simplest and cheapest solution.
    The original metal tip will wear longer than PEEK, I assure you.
    PS: I'm selling PEEK scraps at $.25 a gram, if anyone needs some for a project.
    Dec 2001
    332
    Not if the seat is bad! Carl's is complete and does the job.
    DrSprocket
    Aug 2017
    Fort Mill, SC
    9
    thank you all so much for the feedback. I have sent Carl's an email and will contact them tomorrow.
