Results 11 to 20 of 20
Thread: Serial number ?? 47FL12514 - is it really or fake
    3,629
    Quote Originally Posted by JP66 View Post
    Seller claims motor, frame springrr and wheels are orig.$17.5
    Not all of the motor, JP66!
    I'd knock a grand off its value just for the O-ring manifold conversion, maybe more, as that often did damage.
    Since you can see the fuel filter, I suspect there is no carb support, so the machine isn't even intact.
    Good project though, for somebody with lots of expendable cash and time...
    PS: Usually nothing annoys me more than a clutch pedal stuck in the air;
    But the routing for the advance control coil might.
    PPS: The routing of the sparkplug wires suggest it hasn't run much at all.
    That's probably a good thing.
    Sep 2016
    Oregon
    55
    17.5 is a great price for a running knuckle, even if it is a bit of a frankenknuck.
    making it totally correct would break the bank, but for a rider it has the look of a nicely refurbished bike.
    you certainly won't get hurt buying it for that price.
    Dec 2015
    7
    Learning, thanks for the insight
    Oct 2013
    24
    My 47 is 12391. Now I've seen 3 ohv's built after mine ! I have a question, though. On a motor built that late, what should the date codes on the trans case, lid, and covers be around ? Mine are august/september of 47. Seems too close to 48 production to me.
    2,411
    Two things to keep in mind. '47 was a really big year for H-D and production ran longer than normal to fill all the orders. There was also the push to use up as much inventory as possible. I wouldn't worry a bit about it.
    Oct 2013
    24
    Thanks again ! I can die happy now. haha
    5,206
    Quote Originally Posted by chopsickle View Post
    Should be close to the date code on your engine cases. Aug/Sep 47 is 48 production.
    Jan 2017
    4
    I can't comment on the numbers since I don't know anything but compared to my numbers this one looks good like the others said. As far as price, $17,500 is a killer deal I think. If you do not get it could you pass the seller's info to me please? Everyone wants $30k plus these days even for bikes that are not even close to original. I paid more then that and mine didn't run and needed a lot more then this one.
    May 2016
    12
    wow your numbers are so close to mine within 40 numbers
    looks same as my FL stamping.
    Member # 29257
    Apr 2018
    3
    That number looks fine, a couple hundred over mine and close to the end of production!
