Results 1 to 7 of 7
Thread: 1940's INDIAN Sidecar Gearing Info Needed
    Default 1940's INDIAN Sidecar Gearing Info Needed
    I am in the process of installing an original Indian sidecar on a 1947 Chief. The Chief has a stock 74 cubic inch motor with a 25 tooth front sprocket. I am hoping to hear from some current Indian sidecar owner/operators as to what type of gearing you run. Thanks for any help.
    Feb 2011
    227
    G,day motor-officer i have had a 23 and 24 on my outfit for years running Bonnie cams ,i feel 25 is to tall,Hob
    Oct 2002
    Vancouver, Canada
    35
    When I pulled mine with my '48 stock 74 c.i. motor I used a 23 drive sprocket with and without a 150 lb.+/- passenger.
    Aug 2009
    rural eastern South Dakota
    934
    Quote Originally Posted by jcrawford View Post
    (haven't been here for a bit), .. The year I got my sidecar I was fortunate enough to acquire a handful of sprockets: 28-tooth, 27-t, 23-t, 22-t, and a 19-t, all good shape. The 19 was meant for the Rocky Mountain Road run of 1993 (?), and with my stock 47
    -74 inch I needed it. ... funny, when I tour the Black Hills I get around on a 23 just fine, but I always worked the heck out of the engine. Flat lands the 23 is okay, unless you get a head wind. ..... not sure whether you can still get the 22's and less, ... scout parts?
    happy motoring!
    Jan 2016
    132
    I am running a 23 tooth on my 48 Runs great and I am in Florida.
    My Grandpa's '48 had a 17 tooth front on it. That was really too low unless you lived in the mountains. I don't. I've worked my way up to a 23 tooth front. Acceleration is fine, and I'd say the rig tops out at about 45-50 without really abusing the engine. Or at least my speedometer reads 50, but is likely a lot less. I think a 23 front is about right for around town.
    - Dana
    Jan 2008
    449
    Never counted my gear but I also find running between 45-50 is the spot. Any decent hill I'm downshifting.
