Page 2 of 18 FirstFirst 123412 ... LastLast
Results 11 to 20 of 180
Thread: H-D Production IoE V-twins 1909-1929
    5,140
    I am sure you mean American Machine & Foundry, not AMC.
    3,467
    Also, what made an "automatic" carb different from a "non-automatic" carb ?
    Good question, Folks!
    Hopefully 'automatic' meant it put itself out when it caught fire.
    PS: Before Folks think I am just being flippant, please consider if it has a Schebler H Model with an airvalve.
    (I hope so.)
    582
    Thanks Chris ! of course, AMF, is what i meant !
    582
    (I hope so.)
    Thanks Tom, for your comments. When i read the 1907 featured an "automatic" carburetor, i wondered if "automatic vs. non-automatic" had something to do with mixing air and fuel in a ratio suitable for efficient combustion....? in years past, i seem to recall reading very early, primitive types of carb design somehow regulated the rate fuel dripped into the carburetor, not too much to flood the combustion chamber but enough to allow combustion when raw fuel and air were drawn in to the combustion chamber.....? or, am i just having a fanciful idea.....?
    and, back to Robbie's comment on atmospheric intake valves, this design had no direct mechanical actuation...... ?
    3,467
    I've got no clue about earlier carbs, Steve!
    Nobody has trusted me with one.
    But the advantage of an 'automatic' snuffer should be obvious.
    3,649
    It looks like the '09 double may have a H model Schebler, but there is no way to verify the '08 did. Also, there is no way to know if the '09 originally had a Schebler. There were many different carburetor manufacturers in those days, including Harley-Davidson. As for an automatic carburetor, I know that in those days, some carbs were very crude so perhaps it refers to a carb with a float. As for atmospheric intake valves, they were very common in the early days. Indian went mechanical in 1908, H-D went mech. on their twin in 1911, but not till '13 on their singles. Atmospheric intake valves were simple, and efficient for the slow speeds, and poor roads of the day.
    3,467
    Just conjurin' Eric,..
    But if the legend that Ole Evinrude used a tomato can has any basis at all, wouldn't it have been for a float 'bowl'?
    Using one for a body would certainly have invited a melt-down.
    And it would have been one very, very large "'venturi'"!
    PS: I admitted I'm clueless about pre-George Schebler designs, so any pics or literature would be appreciated!
    2,318
    Correct Steve, they operated by the negative pressure created in the downstroke sucking them open. As simple as it gets.
    3,467
    I suspect, Steve,..
    They had a mechanical means to close the valve: a spring.
    Just like the airvalve on a Schebler H.
    PS: But those were adjustable!
    Any knobs on atmospheric motor intake valves? Shoulda been...
    3,649
    My '11 Merkel twin has atmospheric intake valves; and you're correct, Tom, they have a conical spring return, but no adjustment for spring pressure, or dwell. That was all calculated by the engineers of the day.
