Results 1 to 7 of 7
Thread: "69"shovel
    Oct 2014
    mooresville n.c
    40
    Default "69"shovel
    well here I am agin ,can somebody tell me what casting date's would be on late "69"shovelhead,,please,an thank you cylinder heads
    Apr 2008
    874
    You will need a torch...The casting date is sitting on the top radial fin behind the pushrods.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
    3,649
    Better remind Folks, Steve!
    "Torch" should be for American parlance, a "flashlight".
    Americans can take things quite literal.
    Apr 2008
    874
    Thanks Tom.
    Colonel...don't burn that poor old Trouble head to the ground.
    If you use a "flashlight" you might be able to see the cast date in behind the push rod tubes. Its a cow of a place to see but it should be there.
    Here is an example...even though its a later head. All heads from 1966 had the cast date, but at some stage I think they stamped the date in between the opening of the rocker box....maybe the 80's
    Steve Little
    Australia.
    AMCA member 1950
    Oct 2014
    mooresville n.c
    40
    thank you all for the help
    Oct 2014
    mooresville n.c
    40
    Default "69"
    the HUNT is on....
    Oct 2013
    Maryland
    250
    Whatcha lookin' for, Colonel? Maybe someone here can help.
    Dale
