Results 11 to 15 of 15
Thread: Intake Manifold Leakage
    Jan 2005
    Vancouver Island B.C.
    436
    "Perfect" vacuum isn't achieveable, Dewey!
    But we can produce the same differential with pressure, as one atmosphere is just shy of 15psi.
    So 15psi is overkill, but it will display, with bubbles, any and all possible places for a vacuum leak.
    Even though the motor will never draw extreme vacuum, a tiny leak can still cause grief, or at very least a loss of performance.
    Aye...and what I was getting at is this statement..."as the negitive pressure in the manifold increases and approaches -14.7 psi".
    Since it says -14.7 psi...which is gauge pressure...that would be near 0 psi absolute...which like you say isn't achievable.
    Like you say pressurizing to 15 psi is overkill as a manifold is highly unlikely to see 15 psid. I know the importance of manifold leaks as I had a piston fry on my Sportster 35 plus years ago because of an air leak.
    3,630
    Once upon a time....
    I had built had built a '39 OHV for an associate, and had become quite quite familiar with it, allowed to ride it often.
    It was subsequently sold to a fellow who would return it to me for spring maintenance.
    One year, he said it "ran fine", but it just didn't seem to me to jump like the scalded dog I remembered.
    So a bubble-test showed just a little blister of tiny foam bubbles upon one inlet nipple rivet that took fifteen seconds or so to form.
    I sealed it with my 'secret sauce', retuned, and the owner announced that it ran "like a brand new motorcycle!"
    This leak only robbed performance, but many burnt motors brought to me "ran fine".
    No two leaks behave the same, except those that prevent the machine from running at all.
    Jan 2017
    Winfield,Ks.
    5
    I have a question for Mr. Cotton.You stated in one of your posts that you might not get Viton O-rings to seal.Would you please expound on your theory has to why Viton O-rings might not seal.Viton FKM series O-rings are good for temperatures from approx. -40F to consistent temps.of 425F.They are as fuel proof as any seal produced and are a standard in the aviation industry.Presently I am fighting an intake leak on my freshly refurbished CH and have found the typical aftermarket O-rings to swell upon use indicating their instability when exposed to heat and fuels.Please reply to this question as I am extremely interested producing the best possible assembly with out the use of additional sealing compounds or other home brew methods.
    3,630
    I'm confused Pete!
    I have always endorsed JAMES viton O-rings wholeheartedly.
    (And yes, common O-rings are a lit fuse.)
    PS: The search function brings up nothing, so please link me to the discussion so I can clarify it.
    (If it was my previous post to this thread, I was referring to the stroker geometry problem.)
    Jan 2017
    Winfield,Ks.
    5
    Smile Viton O-Rings
    I'm confused Pete!
    T.Cotton,I'm sure my pondering came from an out of context interpretation of a posted reply to Bill Pedalino on 8-15-2017 in reference to Intake Manifold sealing problems common to both Sportsters and Shovel heads.I'm on a learning curve here and I'm just wanting gather as much experienced advice as possible to help me produce the best possible end product.Thank you for short but concise reply,it keeps me on track.Peter
