Results 1 to 7 of 7
Thread: 1967 GE spark plugs
  1. #1
    Default 1967 GE spark plugs
    Any advice of what spark plug to use in a 67 GE motor? Thanks Dave
  2. #2
    Jul 2006
    Central Florida
    864
    If it's an 18mm plughole, start with a Champion D-16 or equivalent. Won't hurt it at all.
  3. #3
    Aug 2004
    Beautiful Northern New Mexico
    2,355
    Standard H-D plug was a 3-4. The equivalent is a Champion J12Y. The standard iron heads on a '67 are 14mm, unless they have been changed to earlier aluminum heads which are 18mm size. #2 H-D were used on city traffic engines to prevent fouling on continued low speed use.
  4. #4
    The threads are 14mm. so I will go with the 3-4 H-D plugs thanks for the help.
  5. #5
    Aug 2004
    2,355
    Pan620,
    Make sure you use the short reach plugs. H-D also sold a long reach 3-4 which will not work in your GE.
  6. #6
    Jul 2002
    5,152
    Champion UJ12Y work well in my Servi-car.
  7. #7
    Sep 2017
    2
    Just acquired a '66 GE police trike.
    Its spark plugs are marked Champion J16C.
    Good to use?
    What spark plug would be recommended for occasional short distance riding?
    Thank you.
