Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: 'Custom' Tool question: Measuring Manifold nut inside angles?
  1. #21
    3,493
    Quote Originally Posted by knuckcrazy View Post
    If it's that critical send it to me and I'll put it on the CMM and send you a digital drawing of it. B
    I appreciate the offer, Bob!
    But I get a wide range of manifolds constantly (four different ones this week), and you never know what nuts they will show up with.
    Its hardly practical to mail nuts off and wait for them to come back, and I couldn't expect you to do it for free from here on out!
    From the sampling I already have, its obvious that neither OEM nor reproduction nuts (for Harleys anyway) can be assumed to be perfectly consistent.
    BigLakeBob's simple suggestion is quite accurate, and I only have to get up to speed where I don't lose much more time that I can't charge for: I'm too expensive already.
    (But its obvious that my prices must rise eventually, if only to cover the rising cost of material.)
    PS: I googled "CMM", and found I could neither afford one, nor find space for one. Once again, low-tech rules!
    PPS: Its now six different manifolds this week, and the UPS man isn't here yet. I'm going to have to lock the doors 'til after Davenport...
  2. #22
    3,493
    If Bob and Mark and others would like to contribute, Folks...
    We could all start sampling various nuts, and compare our findings here.
    Then everybody could benefit.
    PS: As a follow up, it now appears that the failure I mentioned earlier in this thread was due to a very high angle (whatever the lathe says it was...) nut used with a seal that was most likely patterned off of originals at a much lower angle. Such geometry biases the force of the nut against the inlet nipple at the very outside edge of the seal. The critical sealing is needed inside against the spigot.
  3. #23
    Mar 2017
    144
    Cotton,
    Sorry to jump into this thread late into game. I have been away visiting the spirit world for a week by having a ketamine infusion pain control treatment. Boblakes quote sure has a lot of validity after going through that treatment.
    Now to get back on track, I will call the angle side the front side of the nut. One thing I have noticed is that the readings, using the flat on the back side of the nut, to take the measurements on the front side of the nut will give you a trigonometric sine error because the angle machining process is machined from the front side of the nut. Now this would be fine if the front side and back side were completely parallel, which I am sure they are not because the back side is not a critical measurement and does not have to be held critical, to the front side of the nut, while being cut off. My whole point being is that the front side needs to be indicated in flat to get a proper angle measurement, this can either be done on each individual part before the angle measurement is taken or check each part first to see if the front and back side are completely parallel with each other. The backside must also be burr free by either running a new flat Norton stone across the surface or by running a fine file lightly across the surface. If the front and backside are parallel, then the backside can be pushed against a stop to measure the angle.
    If this makes sense to people on this thread, I will continue on how to double check boblakes compound measurement mathematically. It is very easy to do, but you have to use a scientific calculator.
    Ryan
  4. #24
    3,493
    Ryan!
    Graciously,
    When the nuts are held in a three-jaw chuck against their 'back', the run-out of the 'front' face is readily apparent.
    Most all have been quite parallel, front face to back, and if there is any run-out on the front face, it only takes a gentle nudge to true it within the jaws.
    Once again, the mass-produced seal's failure was due primarily to reproduction nuts with gross error on the angle.
    Considering how many of these nuts I fitted with my own seals without any reported issues, I must attribute success to my different parameters for PEEK.
    Now I can measure all the various nuts for a much more accurate fit.
    It was surprising that fresh brass seals from the same producer as the nuts were similar in error, so as long as you didn't mix sources of nuts and seals, they had a chance.
    (At least as much chance as any brass seal, anyway...)
    The age-old question comes to mind: If somebody is going to the trouble to make a part, why not make it right?
    PS: I hope to measure OEM and reproduction nuts for Sport Scouts, Chiefs, WLs, etc. soon.
    If nobody else wants to contribute their findings, I guess I shall keep my own as "proprietary".
  5. #25
    Mar 2017
    144
    Cotton,
    I sure would report findings, but I do not have any parts to check.
  6. #26
    Ohio
    560
    DSC05687.jpgSometimes I'll use magnets to hold a part at the front of the jaws, quick method that saves a lot of indicating, assuming the front of your jaws are in decent shape. Just wanted to add that if I want the part to not be flush with the jaws, I put a gage block (or equal thickness of any material) under each magnet. This way if I want to machine .05 off a part I might stick .100 blocks under the magnets. I find this method to work well on thin parts.
    Bob Rice #6738
  7. #27
    3,675
    DANG ! That is a good idea, Bob. The only downside I can see, is that it would magnetize your chuck jaws and collect chips. However, the benefits would outweigh the deficits.
    Ohio
    560
    I have not had that problem, the small magnets I use don't seem to have enough to induce magnetism into the larger mass of the jaw.
    Bob Rice #6738
  9. #29
    Mar 2017
    144
    That is a new, great idea, to me as well Bob. Thanks for the tip!
  10. #30
    3,493
    Just need a big de-Gausser, that's all Eric!
    PS: I have two of these, and have never tried them. But I de-Gauss floatvalve needles with a jeweler's coil.
