Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: 1941cruiser green
  1. #21
    Howdy Eric,
    Glasurit and Sikkens are two of the best commercially available paints out there and yes it can get expensive. It is a three part system of color, hardener and reducer and supremely easy to use. In the first 48 hour cure out you can literally shave runs off and wet sand out any imperfection. The manual is very easy to use and mixing is simple with their stick showing the 2 or 3 levels to achieve proper ratio. Their hardeners come in shop temp ranges and they also have deglossers to mix with your color when going with a more authentic sheen like on frames. I've shot 21 and 22 line for almost 28 years most of which only using a Sata mini jet gravity feed touch up gun at 28 a 30 psi. The EPA and the VOC situation is making it a little more difficult for the non-pro to access all of this at commercial paint stores.
    As far as color correctness goes we have a shop here with nearly the entire catalogue of DuPont colors going back to the 30's (that's where I sourced the colors forth 441 in my sig). Not only did the colors, some whimsically named, change from one year to the next, most importantly for authenticity the tint formulations did as well making it nearly impossible to replicate any color having shade variations when viewed in different light settings by using strictly mixes called for in the manual. An original sample has to be digitally analyzed.
    As far as topping existing paint, on a chemical bond (overcoating in less than 48 hours or a period of time where scuffing the surface still yields the odor of solvents) I've hit it with 800 or 1000. If relying purely on a mechanical bond if shooting with a reducer, 600, or if a heavier mix of color and hardener only then possibly 400.
  2. #22
    Jul 2017
    Netherlands
    15
    Get real Folks.
    No modern paint can perfectly match original paints, as they are completely different chemically, and thus reflect a different spectrum of light.
    That's what the whole science of spectroscopy is based upon.
    4% difference is certainly significant to the human eye.
    You were right about the 4% difference ...!
    Last weekend I sprayed some test cards and was not amused seeing the difference between them and the card I got from John Pierce..
    Went back to the shop and they admitted the difference was considerable.They would try to get a closer match but in the end I got a call I got my money back...
    The paint they were using was Standox and it was the only brand they could use together with the spectrophotometer.
    Maybe other brands would give a better result.
    I realise the paintchip John Pierce sent me is already a match to the original but seen the comments here that consider his paint to be spot-on I will try to get a match as close to that as possible,either manual matched or by meter.
    A decade ago I would go through all the fat books with paint samples to get a match in the end but all these books seem to have been dumped..
    The quest goes on.
    Rein
  3. #23
    Jul 2017
    Netherlands
    15
    Finally succeeded in getting a match to the John Pierce paint chip..took 4 adresses to have that colour correct.
    Bought just 2k urethane/ acrylic paint, gloss, no clear.
    First sanded the existing layer with 600/800 and after spraying the new paint sanded it with 1500 and 2000.(3 days inbetween spraying and sanding)
    It removed some slight orange peel and a few small dust particles.
    Then finally "some" elbow grease, rubbing it out with compound to a nice satin finish, shiny but not too much...
    Because of my small garage and being afraid to walk into freshly sprayed parts I did it in 3 stages:
    tanks and dash/ front fender/ rear fender.
    Quite happy with the result ! Weird colour though.. in sunlight it appears more blueish and in the evening it looks more towards green.
    Thanks for all your comments and tips!
    Rein
  4. #24
    Nov 2008
    Virginia
    407
    Looks good to me! I too am doing a 41 knuckle in cruiser green but still wrangling parts so a way off on paint.
    Tom (Rollo) Hardy
    AMCA #12766
  5. #25
    Looks absolutely splendid Rein! Admire your determination to get it right without overdoing the gloss or finish. While other period colors for the early 40's look nice this one really pops and yes, as previously mentioned, can look completely different in various light settings.
