Results 1 to 5 of 5
Thread: XLCH magneto problems
    Default XLCH magneto problems
    I have a stock Fairbanks Morris magneto on a XLCH. I replaced the coil and condenser, cleaned and gapped points as well as replaced the plugs with nos #4 plugs. The magnet seems strong. The bike started and ran well. The next day it wouldn't start. Poking around a little I found the spark intermittent, sparking hot on the first kick then either getting weak or no spark after several kicks. Almost always sparks hot on the first kick after a brief rest. Even before replacing the components it would occasionally spark. Can anyone make sense of this? Thanks.
    5,196
    perhaps the magnets need to be recharged.
    The magnet feels strong and I don't believe that would be intermittent. Any other replies would be appreciated.
    Mar 2005
    777
    Some of the marketer condensers that I've seen are very inconsistent. I would get one from Dave Shaw at Morris Magneto in New Jersey as a starting point. Actually, its probably a good idea to give him a call and ask him about your problem. if anyone has seen it, it's Dave.
    Bill Pedalino
    AMCA 6755
    5,196
    Hopefully not using carbon filament plug wires?
