Results 1 to 4 of 4
Thread: Indian Sidecar Info Needed
    Default Indian Sidecar Info Needed
    I recently pick-up a sidecar. It is stamped with the following number on the frame: SC47 4xx. Does this mean it was produced for the 1947 Indian models?
    A few more questions:
    1. Is there any type of owners/set-up manual for this type sidecar?
    2. It is missing all of the stainless steel(?) trim. Is there any source for original or reproduction trim?
    3. It came with all of its mounting brackets, except the 3-hole frame brake pivot where the sidecar brake rod attaches to the motorcycle brake rods. Does anybody reproduce that item?
    4. Is there any internet sites or real people that are good sources of info for these sidecars?
    Thank you.
    Nov 2009
    Elk Plain, WA.
    40
    1. There is a certain geometry that goes into setup of a side rig to make a bike ride straight. I don't have any for an Indian side car.
    2. There are generic trim catalogs out there, check into the auto body replacement part companies. I have looked into that for my Goulding.
    3. I have never seen a re-pop 3-ear Brake clevis, only originals. I might have an extra somewhere.
    Boone member #15941
    1946 Chief Basket builder
    1939/47 Chief Bobber
    1953 Blackhawk Chief
    1997 HD Roadking
    Mar 2017
    141
    This not for an Indian or Harley sidecar specifically, but it is a good read for a novice sidecar driver, not riding any longer with a sidecar. Only part of the manual will apply, but again reading will help.
    http://motorvation.com/scmanul1.htm
    Aug 2009
    rural eastern South Dakota
    932
    I had to use about a 5/16" shim washer in rear attachment (where roll bar attaches on solo's), to give me about a 3/8" toe-in at front of the wheelbase. And I leaned the bike 3 degrees to the left. Still get the wobble at speed shifting out of first, but it's done 70 mph quite true! .... in my younger days ... sucks to have to say that now.
