Results 1 to 6 of 6
Thread: Heidenau Tires?
    Nov 2009
    145
    Default Heidenau Tires?
    Has anyone put many miles on Heidenau Vintage tires, model K-34? I'm considering using the 3.50x19's for the Cannonball and want to get feedback from somebody that has used them, specifically on a sidecar rig but any input is appreciated. http://heidenautires.com/vintage-motorcycle-tires/
    Thanks! Gene
    1,060
    Dear Gene, I haven't put more than break-in mileage on them but have Heidenau 4.00 x 18 and 4.00 x 19 on several restored bikes now. They have the vintage look, are speed rated, and less expensive than the unrated Cokers.
    Nov 2009
    145
    Thanks Steve, I see all those as advantages over the Cokers. I'm looking for good tires for the Cannonball on my 24 Chief sidecar rig. I'm limited on tire width because of the front spring link width, which is just over 4".
    Gene
    Mar 2008
    New Jersey
    46
    Gene, I have been running a K-34 on my '65 BMW R50/2 for several years. No issues and I like the performance of the tire. It was highly recommended by the rebuilder of the engine.
    Lyle
    Oct 2009
    New South Wales, Australia
    109
    Gene,
    I have found the K-34 excellent on the road. Aussie bitumen back roads most of the time. Usually sit on around 100 kph and found that they handle very well on my VL. The best handling tyre that I have had. The only issue is that I did not get very good mileage from them compared to the Mitas and others that I had run prior. Noticeably quieter and a better ride due to the extra width.
    I did have Cokers originally and if that was all I could get i would park the bike. That is unless they have changed them. The main issue was the grip in the wet. There was none.
    Phill
    Nov 2009
    145
    Thanks for the info Phil. Mileage is a big issue as I'm running a sidecar and would like to avoid changing rear tires along the way, but may have to....
    gene
