Results 11 to 13 of 13
Thread: Harley J Engine Balance Factor. Again!
    Sep 2001
    Palmerston North, New Zealand
    922
    John,
    Perhaps we should stick to Vee twins on this post.
    Multi cylinder, in line engines open up all sorts of other issues that are not present in Vee twins.
    Rocking couple is just one of these.
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
    3,490
    Again I must agree with Tommo, Folks!
    Single-throw V-twins take most of the complications of balancing out of the equation; They don't even know they have two pistons.
    V-twins have such a wide range of acceptable factors that nearly any will run "smooth",... as long as the assembly is true.
    But please note the wide variance of frame support as well, as it is basic to the original factory factor.
    Many of us have suffered "shakes" if the top motor mount comes loose. That's because the motor is suddenly out of balance!
    3,490
    By the way, Folks,
    Did anyone notice a problem with the last "Questions and Answers" page (courtesy of Tommo...)
    Just don't want anyone more confused than necessary,
    (Wish I could have gotten the line more accurate, but everybody should get the idea._
