Results 1 to 5 of 5
Thread: 1940 sport scout leaks from primary chain adj screw
    Dec 2001
    Low Country South Carolina
    147
    Default 1940 sport scout leaks from primary chain adj screw
    After sitting for years, I am getting my 1940 Sport Scout ready to ride. After filling the primary drive with 30 weight oil, I notice that it is leaking from the primary chain adjusting screw at the bottom of the primary cover. Should there be some sort of gasket or sealant there? Not a lot of oil but a small amount over several days.
    Jun 2007
    Catonsville,Md.
    152
    Look hear at Pressure-Rated Metal-Bonded Sealing Washers for Nuts and Washers
    https://www.mcmaster.com/mv1491548656/#3267
    Dec 2001
    147
    thanks for the response, I was hoping someone could tell me the factory way of sealing this bolt and nut
    Oct 2011
    369
    I believe they just used some gasket sealer.
    I either make a paper washer gasket with id small enough that it sort of threads on the screw,or a few wraps of Teflon tape.
    Dec 2001
    147
    That's the information I am looking for, Thanks
