Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 93
Thread: 101 Scout... going to take a while
  1. #61
    Sep 2005
    Sarasota, Florida
    4,183
    I recently had to rework the front fender on my Honda 450. It turned out to be just as much of a headache as any Harley, Henderson, Excelsior, or Indian. The big problem is the fit of the wheel/tire, to the centerline of the fender. That is not only an aesthetic problem, but can be a wheel lacing, or bent fork problem and the challenge is to find out what needs to be fixed (and how to fix it). You really have to take your hat off to every motorcycle manufacturer for making tools, and dies that were/are so precise that mass production produced new motorcycles that looked good.
    Jul 2010
    Vermont
    755
    The special bolt that retains the pinion gear was mangled up something terrible, I wasn't certain if it was a bolt or nut and I wasn't looking forward to taking it off. But it really wasn't a problem, some light taps with a small chisel and it started to turn.
    One can purchase a pinon gear puller, but I decided to see if I could throw one together from scraps hanging around, it's not pretty to look at but it worked like a charm (one more welding job without my reading glasses... need to keep a pair in my tool box!)
  3. #63
    Jul 2010
    Vermont
    755
    I'm a little stumped at the moment and hoping someone can set me straight. I'm reassembling the gearbox and hoping to set main shaft end play but something's not right. When I mount the chain sprocket to the outside splined tube of the driver gear A) I can't get the nut to thread fully onto the end, and B) if I install the smallest .060 thrust washer on the shaft inside then the shaft doesn't protrude far enough to expose the shoulder that the cup for the kicker springs is to ride on:
    the kicker gear lines up inside with the countershaft well:
    and the bearing is fully seated against the case:
    New bearing, but it is the same thickness as the bearing it replaced. And there is also a collar that spaces the chain sprocket away from the case, I purchased a new one and it is the same measurement as the one that came out.
    So, I'm wondering if it is okay to install the main shaft with no thrust washers on the chain sprocket side and two thrust washers on the clutch side?
  4. #64
    Oct 2011
    488
    It looks like you need get your sprocket further on the driver.Im more familiar with chiefs but I think its similar.
    How does the sprocket fit without the spacer behind it?I set the sprocet,then take a measure and sometimes have to adjust the spacer so the nut is full tight just ask the spacer bottoms out to ensure the sproket is all the way home on the splines.
    If the sprocket only goes on that far without the spacer either the sproket or driver is off.With a .030 lock tab under the nut you will only have afew threads on the nut.
  5. #65
    Jul 2010
    Vermont
    755
    Quote Originally Posted by tfburke3 View Post
    How does the sprocket fit without the spacer behind it?I set the sprocet,,then take a measure and sometimes have to adjust the spacer so the nut is full tight just ask the spacer bottoms out to ensure the sproket is all the way home on the splines.
    Thanks Tom, if I reduce the spacer collar then that would do it. My mistake is that I didnít pay attention when I took it apart, but I am reusing most of the original parts. Bearings are new and I did purchase a new collar, but the new bearings and the new collar measure up exactly like the old bearing and collar.
    I toyed with the idea of reducing the collar dimension, but wondered if sprocket alignment (gearbox to wheel) might suffer, and I also wondered if the chain shouldnít be any closer to the gear case. But weíre only looking at a small adjustment....hmmm!
  6. #66
    Oct 2011
    488
    Well it looks like you are paying attention to me.
    Obviously the sprocket position will effect chain align,but you have get the sprocket fully on the driver with a full nut and lock tab.
    What changed?
  7. #67
    Jul 2010
    Vermont
    755
    What changed?
    I donít know! Same shaft, same drive gear, same chain sprocket, same nut to hold on the sprocket, new but same dimension bearing, new but same dimension collar. Oh, and Iím new...I wasnít there when the gearbox was probably rebuilt before!
    (...and I always pay attention to your contributions!)
  8. #68
    This entire build is SUPER. Truly Inspirational.
  9. #69
    Sep 2005
    Sarasota, Florida
    4,183
    Like Tom said, I think the sprocket needs full engagement on the SDG, and I suspect that is where the problem is. Maybe there is a burr on the sprocket, or a wear pattern on the SDG splines that is hanging up the sprocket. Those large, skinny, fine thread nuts are hard to tighten, and always make you have doubts if they're fully seated. I'm just throwing stuff out there as I'm sure you've thought all of this out. I also wanted to say I like your pinion gear puller and think any tool that can get the job done is beautiful.
    So, on mine the nut threads all the way in and tightens against a washer and the sprocket. From what I can see if the nut doesn't tighten all the way in, the sprocket isn't all the way back. If you take the drive gear out and put it together on the bench does it fit then? The nut not threading all the way in doesn't look like a thrust washer problem because the nut should push in on the sprocket which would be limited by the splines on the main gear, not the bearing or mainshaft.
    Also my ratchet cup washer rides against the nut not the shoulder on the main shaft. I checked the wear pattern on the cup washer it looks like it's always been that way. But to be honest I wouldn't have looked if you hadn't said anything
    I don't think it matters to this problem but is the sprocket on the right way? It's hard to tell from the picture.
    I can take pictures of mine if you want. I can even take the drive gear out and put the sprocket and nut on and send you what mine does if you want.
    Good Luck
    Dana
