Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: New tool
  1. #21
    Mar 2017
    141
    Hi Ryan.
    No need for apology. I enjoyed the read on your background.
    I have seen the term (Journeyman) written before, and guessed at the meaning.
    The Australian equivalent of a Journeyman is a Qualified Tradesman.
    A business would screen a bunch of kids and pick the most suitable for a 4 year apprenticeship.
    An apprentice would work under the guidance of a Tradesman and also attend Trade school once a week. Teachers at Trades schools are Tradesman who have been lured back to teach the apprentices.
    When I started my apprenticeship back in 1975 I took home $18.50c a week. Yep it sounds sh!t, and it was, compared to my mates who were getting $80 for unskilled jobs.
    After completing the apprenticeship, my Tradesman wages was pretty darn cool.
    Come on you guys.
    I need suggestions on 3 jaw chuck truing methods.
    I got Ryan paying me $18.50 a week and I wanna feel like a Tradesman again.
    Steve,
    I forgot to add that we also had to have a year of college classes to get a certificate in what was really an apprenticeship. Our employer said they would go ahead and pay for another year of school to get an Associates Degree. The extra year almost turned into two because we were going to school and working. We also had to carry a 3.0 grade point average or the employer would not pay.
    The reason the apprenticeship program became a journeymen's program is because of the union shops. This would allow us to work in our trade in a union shop if we so desired.
    So just the time after graduating high school and going into the Army for 4 years, and then going through the apprenticeship program and working there, 14 years flew by after H.S. graduation. Like I said, my bone infection came back from an old injury. So, I decided school to enroll back to a university to get my Bachelor's degree. So, I did all of that and decided to to go on further to earn my Master's degree. So I then decided to get a job with the least amount of responsibility in a union shop, my first and only time working in a union shop. I did not put on my application that I had already earned my degree or journeyman's card. It was a fun shop to work in called ROCKWELL International, which turned into Meritor Automotive. Anyway, I got recognized, and was told on by some I went to college with. He asked them in the office and asked why I lied on my application. I said I did not lie, I simply did not write fill in some areas. So, I just simply walked out without even telling them I quit. The union kind of saves you from that, so within a month they started laying people off. 5 years later they called me back to work, I declined. I had gotten a job as an Industrial Engineer so I did that for about five years.
    Again, I am rambling Time sure does fly.
    I am writing my next post about the method of the jaws. It is going to be long. First things first, the Chuck has to come off, be taken apart and and be thoroughly cleaned with solvent and be put back together properly. So please do no put them back together yet. Please take pictures an notes, be very thorough. The jaws need to go in the slot that they came from. Some jaws maybe in the wrong place as well. As I said they should be numbered already.
    Also if the jaws come off with two socket head cap screws, make sure the number matches the jaw pad.
    I have to go so take care!
  2. #22
    I think you guys ought to look into getting some soft laws for your chuck, you put them, chuck something up behind them an bore them to whatever you want to turn.
  3. #23
    Mar 2017
    141
    Quote Originally Posted by vride5 View Post
    Hello,
    I agree on somethings they are wanting to do. This trade is not an easy one learn over night. You can also get a set that can be hardened after they are machined. Thank you for you input.
  4. #24
    Mar 2017
    141
    Hi.
    Method 1.
    Thick machined ring placed over external steps on jaws. Open jaws onto ring for uniform outward pressure.
    Grind face of teeth to achieve a uniform face.
    My question on this method is: Does this method (pressure on jaws is reverse to working action)) invite error because slop in scroll might cause jaw misalignment?
    Regards Steve
    Steve
    We used method one on hydraulic chucks, but the ring has to be a highly precision ring, I.d. and o.d. Using this method one, on a chuck with scroll jaws, will keep the o.d. part of the jaws concentric with the I.d. part of the jaws, which to me is very important. The scrolls are very hard on the good chucks anyways. Most are double heat treated.
    One Big Question: Doesn't anyone of you ever want to decide to flip the jaws around to use them for clamping on a larger object or keeping the clamps in place and clamping out instead of in? If so, that is why I recommended the precision ring that locks into the counterbore of the jaws. Locating into the counterbore with this counterbore ring, one could grind the I.d. by clamping in and clamping out to do the o.d. without changing the setup. The counterbore locating ring was all we ever used, again, to keep the jaws concentric.
    This way is by far the best way to grind the jaws to keep the jaws concentric. The next best thing is method 1, with the precision ring. Unless you never decide to flip your jaws around and will be always using them clamping down. If that it the case, then another process needs to be done, but this is not the correct process, but we will go over that next time.
    The next thing, after cleaning, inspection and correct assembly (meaning stoning all assembly surfaces to knock down the burrs and correct jaw number sequence) is to check for is the I.d. flatness of each jaw individually in the Y direction (parallel with the lathe bed) with a test indicator on the carriage. This checks the jaw to make sure they are not bell mouthed, this is the main reason for jaws need to be ground in the first place.
    This is not a simple process for the novice. The more I think about it, the more that needs to be explained. We will get through it though.
    Ryan
    Last edited by ryan; 04-21-2017 at 07:50 AM. Reason: Recording and corrected grammer
  5. #25
    Apr 2008
    830
    Hi Ryan.
    Thanks for today's tuition.
    I did a little lathe job today which needed the compound to be rotated.
    After loosening the hold down nuts I found it was stiff and notchy to rotate.
    I cant remember the last time I moved it, and after a bit of pushing, and pulling, I had a hissy fit and one thing led to another.
    When I came to my senses there were cleaned lathe parts on the bench and a writing pad with slide way tolerance checking.
    I'll get my lathe back together over the weekend.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
  6. #26
    Mar 2017
    141
    Hi Ryan.
    Hello Steve,
    This is a perfect example of why you never use air to blow of chips. Chips get lodged under everything. I always use a small, natural horse hair material, paintbrush and a little magnet on ferrous materials. The oils and cutting fluid seem to destroy man made materials.
    Steve, you are very welcome, I am not sure if I am getting my point across clearly or not. Good luck with putting together your compound.
    Oh, do you take a fine Norton stone to go over the contact surfaces to knock down the burrs?
    Ryan
