Thread: tail light lens retaining springs
    Jul 2014
    Lafayette, Colorado
    34
    Default tail light lens retaining springs
    I have heard there is a tool for installing the two tail light lens retaining springs #5067-39 & #5067-39A, used in all H-D 1939-40 tail light housings, to retain both lenses. Does anyone know what it looks like or better yet do you know a trick to get these two *@#$%^ retainer springs, in place?
    Jul 2017
    Netherlands
    20
    Quote Originally Posted by oldsport View Post
    Probably a little bit late.. It's also for the 1941 ones by the way.
    1947 accessory catalog:
    It's also in Palmers book:
    had to make one myself:
    installed..
    Kind of a struggle to do without it..
    Rein
    Jul 2014
    Lafayette, Colorado
    34
    Thanks for the information. I found the special tool (#11882-39) mentioned in the Palmer's book but did not see any photos of the it in the book.
    I did finally manage to get the two springs installed with out the aid of this special tool, not an easy task.
    Thanks again nukkel for responding.
    Oldsoprt
