Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 65
Thread: 38 Indian Chief
    Jan 2010
    in someone's crosshairs
    208
    The speedo cable issue was easy enough to deal with. I just took a ballpean hammer and pounded a little more relief on the inside of the tank.
    The mounting hole took a little more work. After talking it up with people who have been doing this a lot longer than I have. It was agreed that cutting the tab off and relocating it was the best solution.
    Jan 2010
    208
    Jan 2010
    208
    Aaah, perfect fit.
    Fill in a little of the welding undercut and I'm all set.
    3,647
    Fantastic pictures, Bill. I love seeing set-up, and machining pics. Obviously, you have everything you need to fix any problems that come up Thanks for posting the pictures.
    Oct 2011
    318
    Nice fix.I am now wondering if the set I recently ordered,also 38,will have the same issues.
    I thought I could use a set of 52-53 orig. brazed tanks that are on the self with some small tabs to fill the gap for the smaller dash but apparently the seat post bolt sits about 1/4" higher above the frame tube in a plunger frame and the tank mount tabs would have to raised to lower the tank to clear the seat mount.
    What happened to the rear trans mount?
    Jan 2010
    208
    It got trimmed off at some point, I have no idea why. I'm going to fab a piece to replace it.
    Jan 2010
    208
    Did a little electroless nickel plating. Tried this before with less than perfect results. Parts after they ere glass beaded.
    Jan 2010
    208
    Next they get boiled in an alkaline solution and wire brushed to remove and oil or other contamination.
    Jan 2010
    208
    They're in the soup now. This is part art & science trying to estimate the square inches and the mix of chemicals.
