Page 1 of 9 123 ... LastLast
Results 1 to 10 of 85
Thread: 38 Indian Chief
    Jan 2010
    in someone's crosshairs
    214
    Default 38 Indian Chief
    I've been hauling the frame, front end & wheels for a 38 Chief for the better part of 35 years. I guess it's time to fish or cut bait with it.
    Jan 2010
    214
    Remove the rubber bumper from the front fender and found some original paint.
    I also found that I had a pair of correct cylinders, they're in rough shape but they can be saved. More on that later.
    Oct 2011
    330
    I also have a 38 chief project,but I am no expert.
    I believe your cylinders are 35-37.I believe the lowest exhaust port fin is one fin with the cylinder on 38-39 chiefs.
    Dec 2011
    Falco Colo.
    139
    fish on. that chum n worked.
    gww57.com
    Jan 2010
    214
    You sir are correct. The rest of the engine is a 37 too. It's what I got on the shelf. The purist can cannibalize it after I'm gone.
    Jan 2010
    214
    The bore for the kicker shaft was egged out so I cleaned it up and installed an oversize shaft in it.
    Jan 2010
    214
    Things are progress nicely, I've got a rolling chassis at this point. A big thanks to Greer Engineering for powder coating and lacing the wheels.
    Jan 2010
    214
    These showed up last week, I've been waiting for a year.
    http://imgur.com/4RsnAWv
    http://imgur.com/088coGd
    http://imgur.com/JkdpBJk
    Looking good... keep going!
    Kevin
    Jan 2010
    214
    Rut Roh, I've got a little fitment issue.
    The left tank is pinching the speedo cable against the frame.
    The lower right mounting hole does not line up.
